markfMK
May 14, 2022Guide
RBRE960 IoT Network Slow
hi, I’ve had the RBRE960 for a few weeks and getting amazing speeds from the main network. However, I’m having problems with the IOT network, both in terms of speed and the fact that it keeps droppi...
May 14, 2022Guru - Experienced User
Not sure of the IoT network portion of the system has fast performances as the main wireless networks. The IoT is mostly for IoT items that don't need fast speeds, just to get connected and be used. Most IoT devices don't need lots of speed.
- markfMKMay 14, 2022GuideAgreed on the speed part. It’s more on its stability compared to the main network
- FURRYe38May 14, 2022Guru - Experienced User
Has a power OFF of the RBR for 1 minute then back ON since last FW update been performed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? - Mikey94025May 14, 2022Hero
markfMK wrote:
Agreed on the speed part. It’s more on its stability compared to the main networkHow is your IoT's instability exhibiting itself? I have intermittent issues where after a few days or a week, my IoT network seems to stop accepting connections. I can see it in my iPhone but trying to connect tells me that my password is incorrect. I have to restart my Orbi to get the IoT networking working again, but eventually it happens again.
I engaged Netgear support earlier this year for this issue but we didn't get anywhere, I couldn't reproduce it at will, and it didn't happen during the support engagement so I let them close the ticket. I've not bothered to engage with them again since it remain intermittent and I can restart the Orbi weekly.
- CrimpOnMay 14, 2022Guru - Experienced User
There is only one set of 2.4G radio and antennas. All that is different is Netgear has added a third 2.4G SSID (primary, guest, IoT). The only way that the IoT network would have slower speeds is if the SSID broadcast was modified to advertise only slower speeds. It is not trivial to capture WiFi broadcast packets, so this is not easy to verify. (If I had a 960, I would know in an hour..... but I don't)
Devices connected to the primary or guest networks at 2.4G exhibit different "Link Rates" than those connected to the IoT network?
As for the WiFi network 'disappearing', is that all of the 2.4G WiFi networks, or only the IoT?
