markfMK
May 14, 2022Guide
RBRE960 IoT Network Slow
hi, I’ve had the RBRE960 for a few weeks and getting amazing speeds from the main network. However, I’m having problems with the IOT network, both in terms of speed and the fact that it keeps droppi...
markfMK
May 14, 2022Guide
Agreed on the speed part. It’s more on its stability compared to the main network
May 14, 2022Guru - Experienced User
Has a power OFF of the RBR for 1 minute then back ON since last FW update been performed?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
