ErnieE5
Jul 01, 2024Aspirant
RBRE960 local routing between devices stopped working
ROUTER INFORMATION Hardware Version RBRE960 Firmware Version V7.2.6.31_5.0.24 GUI Language Version V3.0.3.10_2.1.30.3 Operation Mode Router ...
- Jul 01, 2024
As long as you don't reset the devices, they will re-connect to the same SSID name and PW.
Been using same SSID name and PW for years across many different routers. All my devices connect when I either FR or put a different router online using same SSID name and PW.
After new FW is upgraded, can induce some odd issues. Newer code can cause older code or configurations to not work correctly, thus a FR is needed to clear out older or bad code or configurations that may not work right after new FW is applied. Seen this many times after new FW is released.
Yes, default all NG routers use 192.168.1.x which can be changed to something else. Glad this wasn't the problem.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 01, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- ErnieE5Jul 01, 2024Aspirant
The GENERAL action plan you suggested was the FIRST thing I tried. I HAVE ZERO ISSUES accessing the INTERNET, but I DID attempt the reset of the modem "just in case" (In the order you suggested). I am writing this on one of the computers I have been attempting to get communicating with OTHER machines on the local network. Trying to "just" bring up two computers on the network is next to impossible because of all the "smart" devices that use the network. (Sonos, Lights, Garage, Oven, Washing Machine, Thermostat, plugs, TV, and others)
EVERY system/computer that I have connected to the Orbi (wired, 2.4 GHz, 5 GHz, 6GHz - only) has obtained a DHCP address FROM the router AND has been able to access the internet.
What FAILS is machine to machine communications ON THE LOCAL network. (This WAS working up until this weekend and it started failing.) The simplest form of this is attempting to have two desktop computers (with ICMP enabled) trying to ping each other.
If I ping the Orbi (10.5.5.1 ) it responds.
If I ping ANY OTHER DEVICE on the network I get "Destination host unreachable"
In the case above it is a Desktop trying to ping a linux server
The same happens when I try with the Desktop connected via a wire. (No screen shots)I am at a loss to understand WHY this started failing "spontaneously." Up until this weekend I haven't had any issues connecting LOCAL machines via the Orbi. I normally use ssh to connect to the linux machine dozens of times a day...
The linux box ALSO has "Samba" and database ports open, BUT the connection issue is well before this.
This shows the IP address (static via DHCP) given to the linux box and the local open ports:
This shows some various tests from the linux box:
- FURRYe38Jul 01, 2024Guru - Experienced User
Is any Access Controls, Armor or SPC enabled on the RBR?
I can't find (would have never enabled) SPC (assuming it is Parental Controls).
It is a fiber modem from "Spectrum"
SONUV1S, but in the PAST when the MODEM/internet has been down LOCAL traffic has still worked.
