Alexs1993
Jun 10, 2024Follower
RBRE960 Loses internet connection several times a day
So I have the black edition RBRE960 with 2 satellites. I'm not sure why but several times a day, the router loses connection to the internet. Happens several times a day. I k ow it's not our provider ...
Jun 11, 2024Guru - Experienced User
Who is the ISP your with?
Does the front LED turn RED or PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 enabled on the RBR and is native IPv6 supported by your ISP?
How many RBS are deployed?
How many devices in total do you have connected?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
