Tajee
Aug 09, 2022Aspirant
RBRE960 loT displaying under Wi-Fi connections
My installer said the the SSID ORBI14-IoT would disappear a few hours after install of the system. It’s been 24hrs and still is listed under my wifi choices. What is this and should it be listed? My m...
- Aug 09, 2022
Tajee wrote:
My installer said the the SSID ORBI14-IoT would disappear a few hours after install of the system. It’s been 24hrs and still is listed under my wifi choices.The User Manual on page 64 describes how the Internet of Things (IoT) WiFi SSID can be controlled by the user.
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
Nothing is going to happen "automatically". You, as the owner, can use the Orbi admin interface to control the router.
Aug 09, 2022Guru - Experienced User
The IoT SSID always broadcast unless it's disabled by you.
Tajee wrote:
My installer said the the SSID ORBI14-IoT would disappear a few hours after install of the system. It’s been 24hrs and still is listed under my wifi choices. What is this and should it be listed? My main Wi-Fi is ORBI14.
