dtipton489
Aug 28, 2023Aspirant
RBRE960 outdoor satellite compatibilty
I need to add an outdoor satellite module to my mesh system. I having a solar system and it needs to connect to my home wifi. My signal reaches out that far but the solar system will be mounted on t...
dtipton489
The problem is also that the solar is a ground mount system and the all the equipment is to be mounted on the outside of the all metal shop around the corner so the signal is blocked. I need to put an outdoor satellite like you used to able to do with RBK50.
Thanks
Aug 28, 2023Guru - Experienced User
Any chance this solar device has a ethernet port?
- dtipton489Aug 28, 2023Aspirant
I don't know until they come out to install. It is an Enphase system.
Dan
- FURRYe38Aug 28, 2023Guru - Experienced User
I'd ask them if its ethernet supporting, if it is, then to avoid having to install a wifi something out there, a ethernet cable, CAT6A STP to the remote building would be recommended. Then add on a non managed switch in the building and then connect this device to this switch for best connection.
- CrimpOnAug 28, 2023Guru - Experienced User
One might imagine that the company installing this brand of solar panel system has encountered this problem before and might suggest "how we've done this in the past. anyway........
It might be helpful to have a more detailed description of the situation, such as:
- Is this all metal shop attached to the main building, or is it separate?
- If separate, how far away? (as in, "how costly would it be to install an Ethernet cable?")
- Given that the metal shop will completely block WiFi, where can a WiFi device be located that will have a good WiFi signal from the main building and also be visible to the solar panel control box? (toward the roof? at a corner? on a separate structure?)
- Does this proposed mounting location have electrical power?
I would take a serious look at an outdoor rated WiFi Extender, such as the TP-Link EAP110 (<$40US on Amazon)
https://www.tp-link.com/us/business-networking/ceiling-mount-access-point/eap110-outdoor/
Although it is intended for massive corporate deployments, it can also be used in stand-alone mode. See the installation guide, Part 4:
or the User Guide, page 5:
https://static.tp-link.com/upload/manual/2023/202308/20230821/1910013169-EAP110_UG.pdf
It might not be all that difficult to:
- Attach a pole mount to the exterior of the metal shop, either sticking above the roof or at a corner.
- Place the Power over Ethernet (PoE) inside the shop (safe from the weather)
- Run an Ethernet cable (Cat5E or Cat6) through the wall to the extender.
