z7
Jun 01, 2024Aspirant
RBRE960 reboots automatically
Hi, I have RBRE960 with one satellite RBSE960. Both are running on firmware V7.2.6.31. The router, RBRE960 is randomly rebooting. The reboot is very quick, take 2-3 minutes, the LED is blinking ...
z7
Please see the debug and connection statistics below.
Answering your questions:
- front led is white when this is happening
- IPv6 is enabled; guest network, spc and traffic meter is not enabled
- there is no dedicate 6Ghz WiFi enabled
- RBS is connected via wireless
- 1 RBS is deployed
- ~3000 sq ft
- the distance is somewhere between 30-50ft
- yes the router is restarting ocassionally even if the RBS is not in use
- channels are used in this way. I tried with auto but the reboot happened with that config too.
- Yes there are some wireless neighboors, it is hard to quantify. I can see 7-8 networks. Checking the wireless channels I have no conflict.
Jun 02, 2024Guru - Experienced User
How is IPv6 configured on the RBR? Auto, Static, 6to4, 6rd?
Are you using auto detected ISP IPv6 DNS or custom IPv6 DNS?
Who is the ISP service your with?
