MeshedUp
Sep 18, 2022Tutor
RBRE960 reboots itself daily
New RBKE963 system in service a couple of months. Recently, the RBRE960 router began rebooting on its own daily at about the same time of day. The reboots do not occur at precisely the same time, bu...
PeterHo
Sep 19, 2022Aspirant
Mine was doing this very same thing, reinstalled the current firmware which seems to have sorted it.
MeshedUp
Sep 19, 2022Tutor
Thanks, PeterHo,
I'll give that a try.
- TC_in_MontanaSep 19, 2022Virtuoso
The Hitron EN2251 is a Puma chipset based modem. Anything Puma based is notoriously problematic.
I see that this is a voice support modem as well - are you getting voice (telephone) service through this device as well as internet? If so, the next time you see the Orbi drop - pick up the handset on your telephone and see if you have a dial tone.
I had a Hitron based modem from Spectrum - and had similar dropouts - always with a loss of telephone service at the same time. While lights on the modem never changed - all services provided by it were lost including both internet and voice. Spectrum always reported no issues.
If you see this consistently happening, you may want to swap out with a different modem - preferably a different manufacturer. I changed from a Hitron (Ubit made) to a Hitron (Technicolor made) and have not had a single outage since (and that was in January or February).
You may also want to monitor the Connection Statistics page (http://192.168.1.1/RST_statistics.htm) and monitor uptime on the system and uptime on the WAN interface. This will tell whether the router is truly rebooting (System Up-time) or if the WAN Connection (Up-Time on the WAN) is dropping.
- MeshedUpSep 19, 2022Tutor
Thanks for the suggestions, TC_in_Montana,
The older Orbi that was replaced with the RBRE960 never had auto-reboot issues, but I agree that there are likely better modems out there. If (when) the Orbi goes down again, I'll check the phone as you suggest. I believe the Orbi is actually rebooting itself because both wireless and wired connections drop, and the front LED flashes as the device boots back up.
Netgear support recommended re-flashing the Orbi firmware and turning off Armor security, which I have done. Now waiting to see what happens next.
- FURRYe38Sep 20, 2022Guru - Experienced User
I would replace this cable with a CAT6A STP lan cable.
Orbi configured with three separate bands as follows: IoT on 2.4G, computers and smart devices on 5G, and 6G for future smart devices.
2.4G is on channel 6; 5G on channel 40; 6G on channel 69. These channels were selected based on spectrum analysis of neighbors' Wi-Fi channel usage.
Can you turn OFF the IoT and the separate 6Ghz radio on the RBR?
About 31 devices attached and active at any given time.
Home is about 2,500 SF and the remotes are approximately 30' from the base. However, the issue is that only the base reboots.
Please turn off one RBS for now, leaving the other RBS on.
For that size of home, having two RBS deployed is too much:
