itguy97223
Dec 12, 2022Aspirant
RBRE960 Satellite Connection to Base Station
I have the RBRE960 with two satellites. One of the satellites I decided to use hardware for the backhaul connection. But now when I log into the router I see the hardwired connection as good and anot...
itguy97223
I have router and two satellites. One satellite is connected to the router via WiFi backhaul. With IP 192.168.25.200 The second satellite I have connected via Ethernet with IP 192.168.25.201. The second one is wired due to location and interference. The odd satellite with Wi-Fi has IP 192.168.1.250. If I change the second satellite to Wi-Fi backhaul it keeps IP 192.168.25.201. And the odd third one is no longer showing in Orbi router connected satellites. Things do not change if I use IE or Chrome to connect to the router.
Dec 13, 2022Guru - Experienced User
Can you provide a screen capture if what your seeing. Edit out any MAC addresses before posting.
What is the size of your home? Sq Ft? What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
️So the wired RBS had is seeing the .1.250 address? Is this RBS directly connected to the back of the RBR or is there a LAN switch in between?
What CAT# lan cable are you using between the RBR and RBS?
Is the RBS connected using the 2.5Gb port on the RBS and RBR?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- itguy97223Dec 13, 2022Aspirant
Home size is 2600sqft with distance from RBR to RBS around 27 ft. There is a lot of things in the walls and floor that cause poor connection to this RBS that is the reason it is wired. Wiring is all CAT 6. The CAT6 cable is connected to the 2.5gb port on RBS. The firmware I am running on both RBR and RBS's is 6.3.7.5. The odd RBS is the one labeled "where" when i check the firmware on that it says it is running 6.0.3.85 with service unreachable. I have comcast as my provider and I run a Arris Surfboard S33
- FURRYe38Dec 13, 2022Guru - Experienced User
1. You need to update the 3rd RBS to same version of FW as what is on the RBR currently.
2. 30 feet or more distance in between the RBR and RBS.
3. For that size of home you have too many RBS deployed. The RBR and 1 RBS would be enough. I recommend reducing the RBS count be two and reducing the transmit power to 25%. I've got a 5k sq ft home and run two RBS with power set to 25% currently I can get away with one RBS. https://youtu.be/UR0viMLISz4
I have no way of updating the one that is off on firmware. It should not exist. If I unplug the wired 2.5gb connection from RBR to RBS that third RBS (where) goes away. I plug back in and it comes back. I tried to connect to it via IP with no luck. If I run a angry IP scan it does not even find that odd RBS.
I have tried to drop to RBR and one RBS however in that corner of the house the connection is poor and drops many times.
