Worstcase
Jan 25, 2025Tutor
RBRE960 strange WiFi drop
Hi all, I have RBRE960 (Orbi) MESH with two satelites since about 2 years. One Satelite is connected with LAN cable, other with wifi. There is an annoying amount of WiFi drop in every device ...
Jan 25, 2025Guru - Experienced User
turning off the wifi on the provider box doesn't disable its routing function and puts you in a double nat.
What actual modem/gateway do you have?
have you tried putting it in passthrough/modem only mode?
Or the Orbi in access point mode?
- WorstcaseJan 25, 2025Tutor
Hi,
thank you for your questions.
The modem is a F@st 5670. It has DHCP enabled.
The Orbi is in AP mode to avoid double NAT. It is a MESH of 3 Orbi. The Master is on the first floor, where the modem is (about 50cm from the modem). Slave 1 is connected with LAN (it is on the gorund floor), Slave 2 is also on the first floor together with the Master but with WiFi connection (diagonal in the other corner of the house).
