Rd3791
Oct 22, 2024Follower
Rbre960 system rebooting several times per day
Rbre960 rebooting several times per day
Is the front LED turning on RED or PINK when this happens?
Need more details here.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.How many RBS are deployed?
What is the size of your home? Sq Ft?What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter. - FURRYe38Guru - Experienced User
