Badexperience
Feb 09, 2022Tutor
RBRE960 terrible product
Recently upgraged from RBR50 to RBRE960. Product should not have been released without proper testing. I have spent many hours with tech support trying to get the 6E to work. The case goes to the ...
Badexperience
Feb 09, 2022Tutor
Please read all the comments, no just the issue with port 25. The absolute lack of ownership by engineering is shocking as well as your company’s policy that requires the customer to call every six days . If no call is received by NG then the case is closed. That is awesome for the stats NG can publish and raises received for closing cases, but has zero regard for the customer. How is a system like that allowed to be in place?
CrimpOn
Feb 10, 2022Guru - Experienced User
As is often the case, this post manages to combine a number of issues.
Port 25. I view this as a shared failure. Port 25 is "special", and not in a good way. See, for example:
https://www.noip.com/blog/2013/03/26/my-isp-blocks-smtp-port-25-can-i-still-host-a-mail-server/
Thus, the original poster (OP) could have realized that hosting an SMTP server is not something a typical residential customer does and that many ISP's block port 25. While the vast majority of Port Forwarding questions that reach Netgear support are likely to be in regard to (a) Double-NAT, (b) internet gaming, or (c) media servers, it would seem reasonable to expect the Tech Support "script" (what else do we call it?) to recognize that port 25 is "a problem". Once the caller mentions port 25, Netgear support should immediately ask, "Does your ISP block port 25?" (would be even better if the support notes identified which ISPs are known to block port 25 and which do not).
Orbi 960.
This is the first I have heard about:
- Guest network not working on the 960E. In what way? Other posts about the 960 product have not mentioned guest WiFi "not working".
- The 960E blocking Exchange servers. Which servers? Office 365?
These issues appear to have been neglected in the discussion and deserve follow-up.
Netgear Support. This is not the first post to claim that Netgear support has "closed" a ticket when in fact it is far from resolved. And, it is not the first post to claim that a return call was promised that never happened. (Not having a product that qualifies for Netgear support, I have no personal experience to draw on.) Perhaps a private discussion regarding ticket numbers, or are there such things? (i.e. "how did this issue get 'resolved'?)
I confess to being confused by the description of the installation. It appears to indicate that there is one Comcast connection into a Netgear CM11150v modem which is providing internet to two separate systems:
- Orbi RBE960 and
- Watchguard (whatever?) plus....?
This is real puzzle because the CM11150v User Manual appears to go "round and round" about what the ethernet ports 2-4 are used for. i.e. the User Manual says "look at the User Manual" (which is exactly the same thing). Thus, I am confused.
It appears that this has nothing to do with the underlying issues (Port 25, issues with the 960E product, Netgear support),.....or,does it?
- BadexperienceFeb 10, 2022TutorI just received an apologetic email from engineering after I have already received a return for refund authorization. For those that are still stuck with this modem, to be very clear, the guest network will not give access to the internet but the non-guest network will. For those confused about the setup, each network, business and domestic has it own Comcast (ISP) feed going to its own modem (2). They are completely separate systems with their own modems, routers, switches, and range of addresses. This is not common but it allows a good base line for troubleshooting and is necessary for security reasons.
What I am most troubled by is the response, or lack thereof, from the tech support department. BTW the extra support plan was paid when purchase was made, so much for their priority handling. As someone else said, it seems profit over decent service is the prime motivation. I just don’t have the time to help them beta their product.- BadexperienceFeb 10, 2022TutorFurther, the 6E does not and has not worked. After several hours, one tech was able to get the network to show on the available networks but it showed as having no signal strength and was not reachable. That was the closest to resolution after many hours. At times the modem needs to be rebooted to get internet connectivity where the RBR50 worked great. Cameras on the network created by the RBRE960 drop and never did on the RBR50 it replaced. Another concern is there is no way, according to tech support, to import or convert a config file from a RBR50 to a RBRE960. If you have a smart home with programming to devices with reserved addresses, this is absurd for a high end router.
