Graz0
Jan 11, 2023Tutor
RBRE960 Wifi 6 not working
Previously had Huawei WiFi 6 mesh system...cheap but range was poor so I upgraded...#RBE960 is great for the extra output. I previously had super speeds on my iphone 12Pro Max in the old system...but...
- Jan 11, 2023
wifi 6 and 6ghz are 2 different things.
wifi 6 just includes 2.4ghz and 5ghz.
wifi 6E includes 2.4ghz, 5ghz, and 6ghz.
the iphone 12 doesn't have 6E so no 6ghz.
Thats why you can't see it.
Jan 11, 2023Guru - Experienced User
- Graz0Jan 12, 2023Tutor
darn you are so right....6E is different from 6 and how it is implemented by Netgear. In my Huawei I got really fast speeds on a channel that was reserved for 6 only...just like Netgear have for 6E....looks like another router for my switch until Apple can sort some product upgrades....hopefully next iPhone! til then I will wire connections to hardware.
Who knows someone may sort a mac version of a usb dongle for 6E standard...I sure would buy one...
Thanks for your help...and so fast - still no reply from Tech Support on my ticket
- plemansJan 12, 2023Guru - Experienced User
You might be talking about DFS channels. Netgear does use those but on the orbi it uses them for the backhaul (router---satellite) communication. That way the backhaul isn't the bottleneck in speeds.
What speeds are you getting over 5ghz?
the RBKE should saturate most devices over 5ghz without issues.
- Graz0Jan 13, 2023Tutor
Internet speed here in UK on Sky : download 64Mbps, Upload 19Mbms, ping 5ms
Just checked speeds in 5GHz - Main router: - all same room as Router
Mac 1201 Mbps
PC 1201 Mbps
iPad 780 Mbps
iPhone 600 Mbps
3rd party network device 72 Mbps - think this is underfloor heating hub
Lightwave wired hub (IoT)
Satellite 1 5GHz (2 rooms away - same floor)
PC 866Mbps
(should also show a Naim MuSo speaker that is wired into the Satellite network - not showing not sure if this is working ok) - ideas?
Satellite 2 (1 floor down)
Outdoor Nest Webcam 135 Mbps
any pointers gratefully received thanks - all Orbi are wall mounted on brackets in clear space
