F_V
Oct 18, 2023Luminary
RBRE960 Wifi Disconnects/Disabled SSIDs Appeared
Hey all, RBRE960 base and two RBSE960 satellites running firmware V7.2.6.21_5.0.20. Today I lost ethernet connectivity at one of the satellites, and now all of the disabled SSIDs keep appearing inte...
Oct 20, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
It's known that sometimes if the RBS become out of sync that the IoT and Guest Network will show for a few minutes or until the RBS get reconnected or re-synced. Normal operation you'll not see those SSIDs if you don't have them enabled.
