jimmymcmahon
Dec 12, 2023Aspirant
RBRE960 WiFi Speed
Good afternoon. I hope that you are well. A family member of mine has the following setup in his house :- 1 x RBRE960 2 x RBSE960 BT Smart Hub 2 BT Full Fibre 900 The Orbi route...
schumaku
Dec 12, 2023Guru - Experienced User
6 GHz band is enabled? How do I enable or disable the 6 GHz band on my Orbi WiFi 6E System?
Reason asking: These numbers look more like a 5 GHz with some interference due to concurrent 5 GHz networks on the same channels, e.g. the BT Smart Hub one might guess.
- jimmymcmahonDec 13, 2023AspirantHi mate.
Yes the 6 Ghz band is enabled. I tested it on my phone and saw "6" as part of my WiFi symbol.
I was going to disable the WiFi on the BT Smart Hub completely however it looks like the SSID still needs to be broadcasting in order to use the BT Digital Voice telephone service as the phone base unit cannot be hardwired.
