nwallace
Jun 28, 2023Aspirant
RBRE960 with 2 Satellites disappeared several times yesterday and today
I've had the system working "well" since November of last year. There have been minor issues, like walking around the house and suddenly my phone is stuck on "Obtaining IP Address..." and won't conne...
nwallace
Does this happen with the RBS turned OFF?
Not sure, haven't tested with just the router, will test next time it goes down.
Does this happen with both wireless and wired devices?
It's like the route is gone, so yes, both wired and wireless devices don't see it.
What channel configurations are currently set on the router?
3000
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
They are hardwired, Cat6
Are the RBS directly connected to the back of the RBR or is there a LAN switch in between? Brand and model please.
Yes, both RBS and computer connected directly to the back of the RBR
Jun 28, 2023Guru - Experienced User
Does this happen with both wireless and wired devices?It's like the route is gone, so yes, both wired and wireless devices don't see it.
3000
For this size of home, the RBR and just one RBS would be needed. Having two maybe too much and causing problems. Let turn OFF one RBS for now. https://youtu.be/UR0viMLISz4
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.They are hardwired, Cat6
What is the distance between the router and satellite(s)? This is important regardless of wireless or wired connection?
Are the RBS using the 2.5Gb or 1Gb LAN port connection to the RBR?
- nwallaceJun 28, 2023Aspirant
What channel configurations are currently set on the router?2.4 GHz Channel: Auto 5 GHz Channel: 48 6 GHz Channel: 69 What is the size of your home? Sq Ft?
3000
I've seen the video, and while I may need to adjust signal strength, our home configuration is not amenable to just an RBR and single RBS. This may be affecting the connection from walking around the house, but I would be shocked if this was the cause of the router suddenly disappearing after months of not having that issue at all.
40~ft for one, 60 ft for the other, single story home, about 80 ft between the 2 satellites
1Gb LAN port, a LAN switch is connected to the 2.5Gb RBR port, sharing it with other devices
NBS AT&T BGW-320 500
- FURRYe38Jun 28, 2023Guru - Experienced User
3000
We'll come back to this.
What is the brand and model of this switch?
Is this switch a 1Gb or 2.5Gb speed supporting switch?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- nwallaceJun 28, 2023Aspirant
FURRYe38, thanks for all your help with this, I appreciate it. Just wanted to get that out there.
As for the modem, the wifi radios have been turned off since it was installed. It is supposed to be in IP pass through, but I saw that my router has a private IP. I've gone into the modem and changed it to IP pass through.
The switch is a NG GS108, so only 1Gb.
