Sorjal
Dec 20, 2023Aspirant
RBRE960B - can satellites and other wired lan devices use the same ethernet switch to connect?
I'm unsure if this is even possible or if it's a configuration issue. With a RBRE960B Orbi Mesh system, I have the main unit on the first floor of my house. I placed a satellite upstairs and that was...
schumaku
Dec 21, 2023Guru - Experienced User
Reconfigure the NAS to use either DHCP, a DHCP reservation (fixed IP), or at least to an IP address in the same subnet like your RBRE960B 192.168.1.0/24.
Most easy way would be to temporarily configure a PC or a MAC to the 10.x.x.x/?? address on the exact same subnet address config like your NAS.
There is not much sense in configuring a bigger IP subnet, because the system does only support 256 (254 useable) addresses.
