BaneSilvermoon
Apr 27, 2022Guide
RBRE960B compatibility with BGW320-500
Hi, I'm currently running an AT&T Fiber connection with a BGW320-500 modem/router combo unit. First week of March I picked up an Orbi RBRE960B and swapped out my old Netgear Nighthawk for it. I i...
Jun 15, 2022Guru - Experienced User
Ok, well, i believe theres nothing else we can do here in regards to this. This needs to be looked at by NG and Arris to see whats happening and where the fix can be effected. Something NG and Arris will need to dive into.
TC_in_Montana
Jun 15, 2022Virtuoso
BaneSilvermoon Xkennw FURRYe38
I find this interesting.
When you talk about disabling your 6GHz network - are you talking specifically about unchecking the box under the entry labeled 6 GHz Wireless Settings on the Wireless tab?
This does not enable/disable 6GHz SSID - this enables/disables a separate 6GHz SSID - separate being a different 6GHz band from the standard SSID used by the Orbi. To better explain this - If my Orbi SSID is called NETWORKABC, I have a NETWORKABC SSID broadcasting on 2.4GHz, a NETWORKABC SSID broadcasting on 5GHz, AND a NETWORKABC SSID broadcasting on 6GHz.
If I enable the 6GHZ ONLY band using the 6 GHz Wireless Settings in the Wireless tab, then I get another SSID broadcasting on the 6GHz band using the name that I provided in that setting.
At least that is what MY 960 is doing.
So - just curiously - are you providing the same SSID as used on your regular ORBI network in this area - thinking you will have the same network name across all three bands? If so, is it possible that you are creating two SSIDs under the same name on the 6GHz band using same channel - thereby causing something funky to happen? If so, maybe try a different SSID name under that special 6GHz band and see if it corrects that issue.
To verify that your Orbi 960 and MY Orbi 960 are functioning the same - can you verify that you can connect to the 6GHz band using the regular Orbi SSID after turning OFF (unchecking) the 6 GHz Wireless Settings box where it says "Enable 6GHz only network" and hitting apply. If you can not connect on the 6GHz band using the regular Orbi SSID - you may need to forget the Orbi SSID in network settings, then try and reconnect using the device that is 6GHz capable. It also helps if you are on Windows 11 to verify that it is actually on 6GHz - I'm not sure all Windows 10 releases are supporting 6GHz correctly yet.
Thanks!
- XkennwJun 17, 2022AspirantHi ,
To answer your questions, I have always setup distinct SSID names. I did not reuse my main SSID anywhere in settings.
Unchecking "Enable 6 GHz Only Network" is the only change I made to get around the issue reported here, and it was sufficient to address it.
I tried what you mentioned, used the forget network option on my phone, and reconnected and I do see the 6GHz frequency for my main SSID on my phone now; thanks for that tip, didn't know any of that. Nice to know I'm not actually losing the entire 6GHz feature.
So I guess this issue is only related to this separate 6GHz-only WIFI. - TC_in_MontanaJun 17, 2022Virtuoso
I'm glad you found that you still have a 6GHz band available! It's not very well explained in the User Manual - hoping Netgear will update that some day. I think a lot of users believe you have to enable this option to GET/USE a 6GHz SSID.
I think there is still and issue somewhere - the option is there, it SHOULD be usable without taking down the connection. But I'm sure it may take some digging by NG to figure out WHY it is happening.
- BaneSilvermoonJun 18, 2022Guide
That's a good call out. I had noticed that the signal appeared to be registering as wifi 6 on my phone, but so does the IoT SSID (which is 2.4 and 5.0 only) so I figured it was just an anomaly at the time, or registering what the device was capable of. But looking closer at the network information, it is indeed sometimes picking up five signals off of my primary SSID, one broadcasting on channel 213. Though MOST of the time, the Orbi wifi analytics doesn't see that signal.
And no, my SSIDs all have the same name except they end in IoT, 50, and 60.
