BaneSilvermoon
Apr 27, 2022Guide
RBRE960B compatibility with BGW320-500
Hi, I'm currently running an AT&T Fiber connection with a BGW320-500 modem/router combo unit. First week of March I picked up an Orbi RBRE960B and swapped out my old Netgear Nighthawk for it. I i...
TC_in_Montana
Jun 17, 2022Virtuoso
I'm glad you found that you still have a 6GHz band available! It's not very well explained in the User Manual - hoping Netgear will update that some day. I think a lot of users believe you have to enable this option to GET/USE a 6GHz SSID.
I think there is still and issue somewhere - the option is there, it SHOULD be usable without taking down the connection. But I'm sure it may take some digging by NG to figure out WHY it is happening.
BaneSilvermoon
Jun 18, 2022Guide
That's a good call out. I had noticed that the signal appeared to be registering as wifi 6 on my phone, but so does the IoT SSID (which is 2.4 and 5.0 only) so I figured it was just an anomaly at the time, or registering what the device was capable of. But looking closer at the network information, it is indeed sometimes picking up five signals off of my primary SSID, one broadcasting on channel 213. Though MOST of the time, the Orbi wifi analytics doesn't see that signal.
And no, my SSIDs all have the same name except they end in IoT, 50, and 60.
