ScottEOsborn's avatar
ScottEOsborn
RBRE960B Satellite quit working
One of my satellites has suddenly quit working. Have tried resyncing, rebooting, etc., but nothing works. The light works - It pulses, then goes off, but nothing connected to it has access to my netw...
  • plemans's avatar
    Apr 22, 2023
    Have you tried factory resetting that specific satellite and re-syncing it?
    You can also try hardwiring it into the router for the resync.
    What firmware is on the router and on the satellites?
