spb06
May 30, 2025Tutor
RBR/RBS 860 sudden inconsistent connectivity issues
I have a 2 satellite, 860 RBS setup with the RBR running in router mode on firmware 7.2.7.15. 1 RBS is connected via wireless and the other is hard wired. Everything has been stable and runni...
- Jun 02, 2025
I rolled back the firmware to 7.2.6.31 and everything instantly worked.
spb06
Jun 02, 2025Tutor
Jun 03, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
I'd disable auto update on the RBR as well.
Enjoy. 📡
