RiKShaw
Oct 20, 2024Guide
RBR/S 850 backhaul status out of sync and incapable of updating firmware via IP address
Hello, Recently a power out has caused me to examine our wi-fi setup with our Orbi RBR850 router and RBS850 satellites. While fixing a simple disconnection I noticed that the 'backhaul status' for...
Nov 04, 2024Guru - Experienced User
Try this:
RiKShaw wrote:
Hello,
Recently a power out has caused me to examine our wi-fi setup with our Orbi RBR850 router and RBS850 satellites. While fixing a simple disconnection I noticed that the 'backhaul status' for our satellites is "out of sync". In addition while examining the firmware version I have not been able to find a way to update the satellies firmware. On oriblogin.net, the table spaces are blank for the satellies Model Name and Current Firmware Version. It reports that the status of the devices is "Service Unreachable". When I attempt a manual update a webpage open with the satellites IP addresses, but this page fails to load
I have tried:
- Factory resetting the satellites
- Moving the satellites into the same room as the router
- Connecting via an ethernet cable to the satellites
- Turning the satellites off and on
- Turning the router off and on
- Leaving one satellite off and doing all of the above with one satellite at a time
- Trying to access the satellites using the default IP address instead of the one provided by the router
- Generating a new backhaul password and then resyncing
- Updating the router's firmware (successfully updated router's firmware but that is all)
I have not yet tried to factory reset the router, but that is the only thing I can think of doing and I don't particularly want to do that if not necessary. None of the above have resulted in a proper solution.
The most success I have had is that one of the satellites has momentarily reported that the backhaul status was 'okay' but this was only for a few seconds after resyncing. For brevity, the satellites do appear to be working in some regard. The wi-fi network is extended and the internet can be accessed via this extension, despite the issues I'm seeing.
Are my devices defective? Otherwise how can I fix the backhaul status problem and/or update their firmware when I can't access them?
