veranah
May 14, 2022Follower
RBR/S850 -Configuration Backup anomalies
Hi, I unsuccessfully endeavoured to backup my RBR/S850 devices this evenning utilising the Netgear support resource "How do I backup the configuration settings on my Orbi WiFi System - Administratio...
May 14, 2022Guru - Experienced User
veranah wrote:
Hi,
I unsuccessfully endeavoured to backup my RBR/S850 devices this evenning utilising the Netgear support resource "How do I backup the configuration settings on my Orbi WiFi System - Administration-Backup Settings", experiencing the following outcomes:
1. after selecting 'Backup' under ' Save a copy of current settings' the initial response was the file was blocked because of a perceived unspecified hacking threat however, after several repeated attempts a config file was downloaded "NETGEAR_RBR850.cfg". What broswer are you using? This would be browser issue that maybe it's security features seens this as a security issue rather than just a download. I see this sometimes in MS Edge.
2. I opted for Notepad to view the contents and the outcome was a document rendered in an Asian text, which seemed to be untranslatable for this user. The .cfg file is in binary and thus on readable normally using a text editior for security reasons.
3. Subsequently, I discovered some Netgear users opinions which basically discouraged the backup activity on the premise of what I term as 'process weaknesses and avoidable threats'. Where are you seeing this? It's recommended to ALWAYS have a backup configuration safed to file for safe keeping. Helps save time if a factory reset is needed.
4. Furthermore, and without explanation, it appears that Firmware updates V4.6.7.13 and V4.6.8.2 are no longer readily discoverable, and writers are recommending users stay with V4.6.3..... ? This is consistent with my experience this week with the setup app.
v4.6.7x and v4.6.8 versions of FW have been pulled from public use. NG is aware of recent FW issues:
