veranah
May 14, 2022Follower
RBR/S850 -Configuration Backup anomalies
Hi, I unsuccessfully endeavoured to backup my RBR/S850 devices this evenning utilising the Netgear support resource "How do I backup the configuration settings on my Orbi WiFi System - Administratio...
CrimpOn
May 14, 2022Guru - Experienced User
Orbi back configuration files are not plain text. There is a utility program on the internet that decodes config files into ASCII text. There is no security issue with making backups.
- CrimpOnMay 14, 2022Guru - Experienced User
Here is a compiled version of that tool (Windows): https://www.dropbox.com/s/3w1pss8hqk9c2q3/orbicfg.exe?dl=0
Source code is here: https://github.com/Fysac/orbicfg
