ScottTN
Jan 19, 2025Tutor
RBS 350 won’t connect to RBR 750 router
Satellite will no longer connect to router. If rebooted the system multiple times and factory reset the satellite with no luck. Thoughts before I dump the whole system?
- Jan 20, 2025
You will probably still need to downgrade the router to the matching satellites firmware, upgrade the satellite, then upgrade the router. Its a stupid setup when the router can't detect the satellites if the firmware isn't matching.
ScottTN
Jan 20, 2025Tutor
Worked! Although at to update satellites individually. Then router. Now both satellites work and show devises connected to each. Thank you! Saved me from buying a new system.
