Wizzard370
Oct 05, 2023Tutor
RBS 353 satellite connection puzzle
I have RBS353 system. The satellite furthest away from the Base, shows connection at 5G whilst the nearer satellite shows 2.4G. Why the difference? I would expect the further one to show 2.4G distanc...
Oct 05, 2023Guru - Experienced User
Might be an issues of something in the walls/area blocking signal. 5ghz doesn't penetrate materials as well as 2.4ghz.
Have you tried moving it around to see if it helps?
- Wizzard370Oct 05, 2023Tutor
Sure but the one furthest away, with more walls inbetweener, is giving 5G and the nearer one, with less walls, is giving 2.4G
- plemansOct 05, 2023Guru - Experienced User
Certain things in the walls (think hvac/plumbing) are better at blocking signal than others. Its why its worth moving around or swapping the satellites to see what changes.
