sgtgchjr
Oct 14, 2021Aspirant
RBS 50 added to RBR750
Can a RBS50 satellite be added to the RBR750 system?
Oct 14, 2021Guru - Experienced User
Only via ethernet cable can RBS50s work with Orbi AX. There not wirelessly compatible.
- einarsoDec 27, 2021Guide
It actually seems like cabled connection does not either work. Just purchased 750 and was going to use two of my RBS 50 satelites... what a waste of money. Have had 50 router for 3 years, and it died two days ago. I am starting to wonder about the quality from Netgear here. I would really have expected better from them.
- FURRYe38Dec 27, 2021Guru - Experienced User
Well I think NG never intended for the Orbi AC RBS to work at all with Orbi AX. I think for a time they did work wired, however trying with my 1 RBS50 to my Orbi AX, it wouldn't fully connect right or sync. I think that loop hole ws closed in recent FW versions.
