DidierGa
Dec 14, 2024Aspirant
RBS 750 amber blinking
Hello I got a new RBS 750 and when i power on it is blinking - amber.. cant do anything cant factory reset any idea? Thanks
DidierGa
You plug and it s blinking (amber)
Nothing else.
I never saw another color
Did everything 30-30-30, plug on my laptop - no ip, link to the rbr /sync.. nothing
There front led is not even working
You can’t do anything..
Nothing else.
Dec 15, 2024Guru - Experienced User
IF the 30-30-30 reset didn't change the behavior and didn't get the RBS back into a good working state, means that the RBS faulty and needs to be replaced.
