DidierGa
Dec 14, 2024Aspirant
RBS 750 amber blinking
Hello I got a new RBS 750 and when i power on it is blinking - amber.. cant do anything cant factory reset any idea? Thanks
Dec 16, 2024Guru - Experienced User
If its not actually "new" but new to you (a used one), you can try recovering it with tftp or nmrpflash.
Are you on Windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walkthrough using a TFTP client. Use the built-in one for Windows 10, though. The video is more of an example of how it's done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Here's a video of nmrpflash: https://www.youtube.com/watch?v=qxQu3wtpFYo
DidierGa
Dec 16, 2024Aspirant
Hello
Thanks a lot for your respponses.
I dont know how but yeserday the light was green
So i decided to upgrade the FW.but i cant..
i tried to login to the interface and it time out
I used the tftp and doesnt push it.
When i did an IP -t on the satellite i saw some instability
couple of response but lots of time out / host unreachable.. and that why i cant upgrade the FW.
So i think it s dead...
Thanks
DD
