bearlai0910
Jun 25, 2024Aspirant
RBS 750 cannot connect rbr750,,
RBS keeps flashing white light When I press sync between the satellite and the host, the light will turn purple~ I have tried connecting the satellite and the host together using an ethernet ca...
Jun 25, 2024Guru - Experienced User
Title says 750 while you mention 850?
Did the RBR set updated before the RBS did? If so, you may need to downgrade the RBR back to what had been loaded on it.
bearlai0910
Sorry~ When I first installed it, he reminded me to update and clicked OK...
How should I downgrade the router? thanks
- FURRYe38Jun 26, 2024Guru - Experienced User
Download the FW file for the RBR from NG download site for the RBR750 and send it to the RBRs web page:
- bearlai0910Jun 27, 2024Aspirant
But I don’t know the satellite version~ Should I try one by one?
Is there a way for me to update RBS? 192.168.1.250 cannot be accessed
- FURRYe38Jun 27, 2024Guru - Experienced User
Try 192.168.10.250 on the RBS after waiting 5 minutes after you factory reset the RBS and don't sync it to the RBR.
Try one version back...
