bearlai0910
Jun 25, 2024Aspirant
RBS 750 cannot connect rbr750,,
RBS keeps flashing white light When I press sync between the satellite and the host, the light will turn purple~ I have tried connecting the satellite and the host together using an ethernet ca...
bearlai0910
Sorry~ When I first installed it, he reminded me to update and clicked OK...
How should I downgrade the router? thanks
Jun 26, 2024Guru - Experienced User
Download the FW file for the RBR from NG download site for the RBR750 and send it to the RBRs web page:
- bearlai0910Jun 27, 2024Aspirant
But I don’t know the satellite version~ Should I try one by one?
Is there a way for me to update RBS? 192.168.1.250 cannot be accessed
- FURRYe38Jun 27, 2024Guru - Experienced User
Try 192.168.10.250 on the RBS after waiting 5 minutes after you factory reset the RBS and don't sync it to the RBR.
Try one version back...
