indyles
Jan 18, 2021Follower
rbs 750 connecting to a rb50yv2
I have purchased and setup an rbs750 with two satellites. That is working fin. I have an rbs50yv2 that was running in extender mode and I have reset it to run in orbi mode (white light flashing(. b...
CrimpOn
Jan 18, 2021Guru - Experienced User
indyles wrote:I have purchased and setup an rbs750 with two satellites. That is working fin. I have an rbs50yv2 that was running in extender mode and I have reset it to run in orbi mode (white light flashing(. but I cannot get the rbs 750 to recognize it. Any suggestions?
vajimis correct. The RBS50Y will not work as a satellite on WiFi 6 Orbi models. See the top of page 6 of the User Manual:
To add the Orbi OutdoorSatelliteto your WiFi network,you must own an Orbi router.
The Orbi Outdoor Satellite is compatible with residential and business Orbi AC routers.
Note:The Orbi OutdoorSatelliteis not compatible with Orbi WiFi 6 models.Visit netgear.com/support for more information about which Orbi models your Orbi Outdoor Satellite is compatible with.
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_UM_EN.pdf
