cpmassen
Jul 19, 2022Apprentice
RBS 750 Constantly disconnecting
I have this exact same problem (have had it now for several months) and it is so annoying. Only the devices connected to my satellite on the far side of the house and back deck (TV) are affected. I...
cpmassen
My satellite continues to randomly disconnect all throughout the day. Is there a fix for this? It has been going on for months!
Jul 19, 2022Guru - Experienced User
Are you still on this version of FW?
There is newer FW available:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- cpmassenJul 19, 2022Apprentice
This is the satellite firmware
Satellite RBS750 Living Room Satellite V4.6.5.14 No New Firmware Available I am using xfinity for my ISP and I have the ORBI CRB 750 with the built in cable modem.
Router CBR750 CBR750 V4.6.5.8 No New Firmware Available 3100 square foot home. And the satellite is 30 feet (maybe a few more) away from the main unit.
- FURRYe38Jul 19, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update?
Set CTS to 2347
The CBR and RBS750 are apart of the CBK752 system, thus we've moved into the right forum location for your system.
Also this is the support and FW download back for both the CBR750 and RBS750 that comes in the CBK752 kit:
https://www.netgear.com/support/product/cbk752.aspx#download
This is not be confused with the RBS that comes in the RBK752 kit. These are different thus FW is different as well.
- cpmassenJul 19, 2022ApprenticeI was using Auto on the 2.4 and 48 on the 5.0 but switched them to 6 and 40 after reading that may help but it didn’t help at all. Yes I have Wi-Fi neighbors next to me and behind my house. Not super close but in a neighborhood. I just completed my second full factory reset of the system last week. I did find it interesting the satellite retained the same custome name I had given it after I reset the system. Is there a way to factory reset just the satellite to default settings?
Is my firmware the most updated on both devices?
I can change the CTS now to see if that helps.
