Hammyhouse
Aug 11, 2022Tutor
RBS 750 Constantly disconnecting
I have been having the exact same issue and mine are about 35 feet apart directly across from each other. Spoke with support they said to do a shock reset to it. Still doesn't work right. Going to op...
Hammyhouse
Aug 11, 2022Tutor
Firmware version v4.6.8.2
I forget what model the modem is but i dont think its the issue as the router never goes down. When the satelite goes down i still have working service on the router( wifi and ethernet) its just the satellite that goes down.
Single story 2100 sq ft, one is placed in the far back room which is my office and then ine is in the front by loving room tv. I did measure with measuring tape its about 35 ft away from each other.
On the satellite it has two ring devices wifi, pc (hard wire) , ps5 wifi , amazonfire stick, nest connect, ring bridge.
Reason i got this is i have a lot of smart appliances and was told this could handle a decent amount of devices.
Now i do only have 500 internet , but would router go down as well if isp issue?
Aug 11, 2022Guru - Experienced User
What channels are you using on the RBR? Try channel 1 and 40.
Is the FW on the RBS same as on the RBR?
Might try turning down the power output of the RBRs Wi-Fi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Also enable SIP ALG under Advanced tab/Setup/WAN Setup
- HammyhouseAug 11, 2022TutorSatellite is on the same fw.
At work so when i get home i will make those adjustments.
Router is on entertainment system under 65 tv. Thinking of moving it away or mounting on wall for less interference?- FURRYe38Aug 11, 2022Guru - Experienced User
đ
- HammyhouseAug 12, 2022TutorSet 2.4 tomchannel 1 , 5 was at 48 already
Changed router wifi signal to 50%
I believe i had sip enabled already, says check to disable and the box isnt checked and says secure.- KevinLiTSep 02, 2022NETGEAR Moderator
Hello Hammyhouse,
Welcome to the NETGEAR Community!
Are you still experiencing disconnection issues with your RBS750?
Best,
Kevin
Community Team
