orbiterrible
Apr 15, 2022Follower
RBS 750 no devices connect
No devices connect to the satellite. Stop asking me if my satellite is 40ft away It is. Zero support from orbi. The satellite hosts no devices ever. Finding a solution in the “forum” is a fools err...
tucsontico
Apr 15, 2022Virtuoso
The primary reason for satellites not connecting devices is a lack of communication between the router and the sats. This can be caused by several things. Normally, it is due to an improper sync between the router and the sats. Try to re-snyc them first. If that doesn't solve it, be certain that the router and sats are on the exact same firmware version. If not, update the sats first, then the router. If none of this works for you, it is most likely a hardware problem. Return them system and get a new Orbi or another manufacturer"s device. Good luck!
