centaros's avatar
centaros
RBS 750 out of sync after rebooting the router
Hi,   I once rebooted my RBR750 and one of my RBS lost sync.. it showed solid magenta. So I tried the sync few times but it never made it working again. Then I deleted the satelite in the router c...
  • FURRYe38's avatar
    IF you removed the RBS from the RBR, try a factory reset on the RBS by pressing the reset button for 15 seconds then release. Then try to re-sync to the RBR. Try a factory reset on the RBR and RBS as last resort.
