centaros
Sep 02, 2021Aspirant
RBS 750 out of sync after rebooting the router
Hi, I once rebooted my RBR750 and one of my RBS lost sync.. it showed solid magenta. So I tried the sync few times but it never made it working again. Then I deleted the satelite in the router c...
- Sep 03, 2021
IF you removed the RBS from the RBR, try a factory reset on the RBS by pressing the reset button for 15 seconds then release. Then try to re-sync to the RBR. Try a factory reset on the RBR and RBS as last resort.
centaros
Sep 03, 2021Aspirant
Hi FURRYe38 ,
I tried few thing based on what you mentioned. But they didn't work. Please take a look.
Trial #1
- Pull the satellite power adapter from the wall for 1 min and put it back
- Pressed the sync button of the satellite
- Ran the sync process in the app. Sync failled.
- Got solid magenta LED on the satellite.
Trial #2
- Pressed the reset button for 10 seconds (nothing happened)
- Pressed the sync button of the satellite.
Trial #3
- Pull the power adapters of modem, RBR750 router and the satellite from the wall for 1 min and put them back.
-JL
Sep 03, 2021Guru - Experienced User
- centarosSep 03, 2021Aspirant
Hi FURRYe38,
I tried this -
- Long press the reset button of RBS little bit more than 15 seconds. The power led was blinking orange while I was pressing.
- After releasing the button, the front LED started flashing white.
- I waited about 2 minutes then front LED became solid white.
- I pressed sync button once and did Add Orbi Satellite in the web GUI.
- The satellite's front LED started flashing white during the process. Then it got off and sync failed.
- I repeated #4. The LED got solid magenta.
-JL
- centarosSep 03, 2021AspirantReset everything including the router and the satellite started working again.
- FURRYe38Sep 03, 2021Guru - Experienced User
Glad the reset worked.
Enjoy.
