Zooss
Aug 17, 2021Tutor
RBS 750 "Out of sync"
Received a replacement RBR750 due to RMA, but kept original satellites. One satellite syncs, but the 2nd will not sync and only syncs when pluged in via ethernet. When logged into router via PC, it s...
- Aug 17, 2021
Turn OFF the 1 RBS. Select REMOVE from the RBRs web page for the "disconnected" RBS. Factory reset the RBS and place the RBS near or in same room as the RBR and re-sync it. Press the sync button on the RBS first then RBR.
Keep checking the RBRs web page for sync status. Should get GOOD.
Zooss
Aug 17, 2021Tutor
Just did this again and got a solid magenta light on RBS while RBR is pulsing white. Satellite 2 is not showing up in web interface.
Zooss
Aug 17, 2021Tutor
Did it a few more times, waited a long time after pressing sync and the magenta light went away eventually. Not sure what finally did it, but thank you for your reply and help.
- FURRYe38Aug 17, 2021Guru - Experienced User
Glad you got it working.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy.
