Andrewh37
Aug 08, 2021Aspirant
RBS 750 Poor Backhaul Green LED after Reset
Hi, I have an Orbi RBR 750 and three RBS 750 satellites. My system worked very well for six months. Recently one of my satellites keeps, losing connection, then the white light flashes and the LED li...
- Aug 09, 2021
Try leaving off the 1 RBS and move the other RBS around so that is give some coverage to the Kitchen area...
Aug 08, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Swap locations with other RBS to see if the problem follows the RBS or remains?
Andrewh37
Furry, I tried swapping satellites and the same green light came on and the Backhaul was poor so it looks like it is the location. But I don't understand the green light. Amber and Magenta are meant to indicate no connection and a poor connection. The netgear documentation makes no mention of a green light. Thanks for your help Andrew
- FURRYe38Aug 08, 2021Guru - Experienced User
So swapping RBS at this location seems to keep a green front LED at this location with the different RBS and does not follow the previous RBS?
What is the distance between the router and 📡 satellite(s)?- Andrewh37Aug 08, 2021Aspirant
Furry, so I swapped another satellite into to problem location and it was showing a green light on reboot. I put this satellite back into its old location and it showed blue after reboot. I also put the satellite in the problem location into a new location and it was blue on reboot. So I think the green light is due to location not an individual satellite fault.
My house has three floors but everything is ok apart from the problem location in the kitchen which which is on the same floor as the router but is probably 40 or 50ft from the router.
This location was blue when I originally set up the system. Once again thanks for the help.
andrew
So all working now?
