Andrewh37
Aug 08, 2021Aspirant
RBS 750 Poor Backhaul Green LED after Reset
Hi, I have an Orbi RBR 750 and three RBS 750 satellites. My system worked very well for six months. Recently one of my satellites keeps, losing connection, then the white light flashes and the LED li...
- Aug 09, 2021
Try leaving off the 1 RBS and move the other RBS around so that is give some coverage to the Kitchen area...
Andrewh37
Furry, I tried swapping satellites and the same green light came on and the Backhaul was poor so it looks like it is the location. But I don't understand the green light. Amber and Magenta are meant to indicate no connection and a poor connection. The netgear documentation makes no mention of a green light. Thanks for your help Andrew
Aug 08, 2021Guru - Experienced User
So swapping RBS at this location seems to keep a green front LED at this location with the different RBS and does not follow the previous RBS?
What is the distance between the router and 📡 satellite(s)?
