Andrewh37
Aug 08, 2021Aspirant
RBS 750 Poor Backhaul Green LED after Reset
Hi, I have an Orbi RBR 750 and three RBS 750 satellites. My system worked very well for six months. Recently one of my satellites keeps, losing connection, then the white light flashes and the LED li...
- Aug 09, 2021
Try leaving off the 1 RBS and move the other RBS around so that is give some coverage to the Kitchen area...
Andrewh37
Furry, I still have the problem that that I have poor Backhaul in the kitchen and I do not know why the satellite shows green rather than blue, amber or magenta,
andrew
Aug 09, 2021Guru - Experienced User
- Andrewh37Aug 09, 2021Aspirant
Furry, I have move the RBS and it is now blue after reboot and has good Backhaul. Thanks for your help. The meaning of a green light will remain a mystery! All done
thanks Andrew
- FURRYe38Aug 09, 2021Guru - Experienced User
I'll see if I can find out what the GREEN LED means.
Glad the move worked. Enjoy.
:smileywink:
