wahhabm
Jul 05, 2023Aspirant
RBS 750
Hi, I am running the RBR 750 router with 4 satellites RBS750. This morning my wife tells me that the Satellite in the garage had an amber light. I went out there and tried to reset it by unplugging...
wahhabm
I also tried to log in 192.168.1.250 and I was not successful kept getting an error that the site can't be reached possibly a proxy and firewall setting which I don't know how to get around
Jul 06, 2023Guru - Experienced User
Try 192.168.10.250 after you factory reset the RBS and don't sync it. Give 5 minutes and check with a ethernet connected PC.
If you can get to the RBS web page here, what FW version is loaded?
Try turning OFF all other RBS and bring the one RBS to the same room as the RBR.
Try the Generate New Backhaul PW then try to sync.
Try the Add Satellite button on the RBRs web page.
What FW version is loaded on the entire system?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- wahhabmJul 06, 2023Aspirant
Try 192.168.10.250 after you factory reset the RBS and don't sync it. Give 5 minutes and check with a ethernet connected PC. This did not work either
If you can get to the RBS web page here, what FW version is loaded? N/ATry turning OFF all other RBS and bring the one RBS to the same room as the RBR. I need to try later on
Try the Generate New Backhaul PW then try to sync. I don't know how to do this
Try the Add Satellite button on the RBRs web page. It didn't work
What FW version is loaded on the entire system? V4.6.14.3_2.3.12
What is the size of your home? Sq Ft? 3000 SQ FT with lots of bricks inside
- FURRYe38Jul 06, 2023Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
Possible RBS may have gone bad. Being in the Garage, some outside environment conditions could play a roll in this.
- wahhabmJul 06, 2023AspirantIt has been getting to 100 degrees inside the garage. I guess it killed it
