Xendercage
May 03, 2024Star
RBS 760 losing connection with blackhaul or wifi when confiured as AP
Hi I have a dual Orbi 760 pack with a router a and satelitte. When i configure Orbi as an Acess Point to prevent double nat between my main routers and ethernet connected devices with the wifi mana...
CrimpOn
May 03, 2024Guru - Experienced User
There has been no change in the wiring connecting router and satellite? i.e. the cable path from the router LAN port to one of the satellite LAN ports? No switches added to the configuration?
- XendercageMay 04, 2024Star
Hello
No changes at all between the two configurations.
Switch exits and are connected directly on my ISP router in both situations
- FURRYe38May 06, 2024Guru - Experienced User
What is the Mfr and model # of the host router or ISP router?
Brand and model# of this switch?
Is RBR connected to the host router using it's yellow WAN port while in AP mode?
How are RBS connected to the RBR in AP mode? Wireless or wired?
- XendercageMay 10, 2024Star
Hello
ISP router is French Orange Livebox 5
Livebox 5 Orange, plus de confort pour toute la famille
Switch is a TP-link LS108G
RBR Cannot be connected to RBS using ts yellow port as the only yello port on my RBS is to receive internet from ISP router. AP or router mode are the same it needs my ISP router on yellow port named "internet".
I have tested both wired and wireless between RBS and RBR and same thing happen.
RBS in router mode : connection is stable
RBS in AP mode : connection is lost after 12/24 h
