fangruoyuan
Sep 19, 2021Guide
RBS 850 DEBUG PAGE
NG please correct the "RBS750 satellite" wrong info in RBS 850 debug page. (V4.6.3.16, on the top right)
Sep 19, 2021Guru - Experienced User
There a screen capture of this?
- FURRYe38Sep 19, 2021Guru - Experienced User
See that on mine as well: :smileyfrustrated:
Hopeing this is just a UI page typo.
Also noticed that I can't factory reset the RBS and log into it's web page 192.168.1.250 after 5 minutes with a wired PC. Wired PC connected to RBS does NOT get an IP address. I see it's default SSID being broadcast however it only seems to last a few minutes then stops. I can connect to it's default SSID name and default PW.
Also noctice when I get connected to the RBS web page while I can, Wireless mode : Up to 573 Mbps appears. I belive this value is incorrect:
- Blanca_OSep 21, 2021NETGEAR Employee Retired
Hi fangruoyuan and FURRYe38
This has been brought up already to the product team. We will get back to you guys for any updates.
Blanca
Community Team- hide2021Oct 09, 2021Tutor
The same thing is happening with my RBS850.
When will the fixed version be released?
