jkk4_1998
Mar 06, 2022Apprentice
RBS 850 Satellite Update Problem
Trying to manually update my RBS850 to fw 4.6.7.13. When I go into Administration to start update, it says "Service Unreachable". I'm unable to update the FW on my Satellite. What's going on here? T...
- Mar 07, 2022
đ
jkk4_1998
I am only doing the manual update.
running NG CM2050v modem from xFinity. RBR 850 set up as router and one RBS 850 satellite connected wirelessly.
So I go into Orbi login.com or 192.168.1.1 to access my router. I then go to administrative and select manual update. I then check off my RBS 850 to update. Click continue and nothing happens. Window pops up with my satellite IP address, but nothing happens to allow me to add the few file.
When I check online update, router says "no new firmware", Which I understand. It then shows my Satellite and it says "Service Unreachable".
Both are currently running v4.6.3.16
Mar 06, 2022Guru - Experienced User
You'll need to manually download the FW files first and unpack the .zip files. Then connect to the RBS web page in a web browser directly. Use the IP address seen on the RBRs connected devices page to access the RBS web page. Send the RBS FW file to each RBS first, then update the RBR lastly.
- jkk4_1998Mar 06, 2022Apprentice
Well, that is where the problem lies. I've already downloaded and unpacked the files. If I go into 192.168.1.1, then how do I get to my Satellite page? i know it's IP address but where would I type in it's IP?
In Manual update I click on the Satellite to update, then click continue. A window pops up for my Satellite IP and it's just blank.
Tried all sorts of browers, including Using a Mac and a Windows 11 PC. "Service Unreachable".
Even though I['m gett perfect connection with my Satellite, do you think I should reboot it?
- FURRYe38Mar 06, 2022Guru - Experienced User
jkk4_1998 wrote:
Well, that is where the problem lies. I've already downloaded and unpacked the files. If I go into 192.168.1.1, then how do I get to my Satellite page? i know it's IP address but where would I type in it's IP? Into another new tab on your web browser or new web browser window.
OK, typed in and getting no response with that IP address. Maybe reboot to see what happens? Seems to me this is a netgear problem and not mine. My Satellite works perfectly. I've googled and see other people have had problems before.
