KevanC
May 23, 2023Aspirant
RBS 850 won't take an IP address
Setup:
I have a Metronet fiber optic modem that is connected to a Firewalla Gold (DHCP mode). The Netgear Orbi router is in AP mode connected to the Firewalla. Then, I have two satellites (RBS 850) hard wire connected via cat6 through my house. This system has worked flawlessly for years. I do occasional reboots when there is a problem.
Problem:
My satellites have dropped off the system. I get a solid magenta light (unable to obtain IP). I have tried to reboot just the satellites. And, I have rebooted the entire system and incrementally powered the appliances in order from the modem down to the satellites. I still get the same result. There is nothing that has changed on my system. I just noted the satellite in my living room was magenta. Any suggestions on how to fix this?
Firmware Version
V4.6.14.3_2.3.12
The most obvious place to examine is the cable path. With typical home wiring, there will be a number of RJ45 connectors plugged into RJ45 jacks. (Maybe there is even a switch in the path, which means more connections.)
What happens if the satellite is temporarily located next to the router and connected directly to the router with a short patch cable?
- KevanCAspirant
I haven't tried them. I have a switch for each one. The other devices connected still show a stable connection. It's just the satellites. I thought it was odd that it's affecting both of them at opposite ends of the house. I'll try to move them. It will take some work.
What is the Mfr and model# of the ethernet switch in the configuration?
Do they connect and work correctly when connected directly behind the RBR?
The RBS needs to be connected behind the RBR:Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
