CloudAtlas
Nov 08, 2023Aspirant
RBS 860 - ethernet disconnects
Hey everyone, Wanted to see if anyone has ideas on the cause. I have no issues with the RBR860. Recently purchased a RBS860 to improve the connection at the back of the house approx. 1500 sqft. ...
CloudAtlas
Firmware is now matching between RBR to RBS to V7.2.6.21
Approx. 25-30 feet, there are three walls between.
Let me know if this is the info you are requesting regarding channel configurations:
AX enabled 2.4 GHz and 5 Ghz
2.5 GHz channel: Auto
5 GHz channel: 40
Also have the IoT Network enabled and most of our smart devices are connected through that 2.4 GHz only
Nov 09, 2023Guru - Experienced User
Let us know if that fixes things...
- CloudAtlasNov 11, 2023Aspirant
Hey FURRYe38,
Thank you for following up. The connection has been stable. Still experiencing some latency issues but that could be unrelated - going to keep troubleshooting that on the PC/ISP side. Updated the ethernet port drivers on the PC when I matched the routher/satellite firmware. So overall a drastic improvement from the frequent disconnects.
- FURRYe38Nov 12, 2023Guru - Experienced User
Good to hear. Come back and let us know the final outcome.
- CloudAtlasDec 06, 2023AspirantHey FURRY,
Same issue with the satellite is back. Frequent disconnects when hardwired and no issues when wireless. Any other thoughts on what could be happening?
