dcraig
Aug 22, 2020Guide
RBS connecting to RBR at only 100 mbps over long Cat5e run
I removed two switches from in between an RBR850 and a RBS850 (wired backhaul) to solve a Guest network problem where the Guest network would not broadcast over the RBS850. I found that removing the...
- Aug 22, 2020
Thanks Fury. The Cat5e works fine between two gigibit switches, so it appears to be the RBR and RBS having a problem with it. But I solved the problem with your input from the other post. With a GS108 switch on each end, and the RBR and RBS connected to the switches, they connect up properly and the Guest network functions as designed. Luckily I had an extra GS108 to try. It was the GS724Tv4 24-port managed switch that was causing the problem, even though I had previously disabled all IGMP protocols and green features.
FURRYe38 wrote:I would run CAT6A if your wanting a long run for ethernet.
I cable you have may not of be good quality for a long run like that.
Aug 22, 2020Guru - Experienced User
