CrazY_l3oYz
Jan 09, 2022Aspirant
RBS20 is unable to connect to my router RBR750
Hi, my RBS20 is unable to connect to RBR750. It keeps failing regardless I'm using the phone, computer, or syncing directly from the router and satellite itself. These are what I received:- ...
agagon
Sep 30, 2023Aspirant
I tested it and surprisingly works, as I mentioned on my previous post. Here are the screenshots:
The caveat is that I was unable to access the admin web page (http://192.168.1.250), hence I am unable to change the network name, since I wanted it to have the same one as 802.11ax network. I tried many combination of passwords, just to name a few I tried:
admin/password
admin/(same password as route console)
admin/1234
admin/(blank)
admin/admin
(blank)/password
Here is the WIFI that I was able to connect to:
CrimpOn
Sep 30, 2023Guru - Experienced User
Thanks for reporting the results. I would say it almost works. The router sees that something is connected, but cannot manage it. Little things like
- Cannot set the WiFi SSID
- Cannot set the WiFi channel
- Probably cannot specify Access Control parameters
- Cannot assign the satellite an IP
How did you learn the password for the satellite WiFi (ORBI63)?
- agagonSep 30, 2023AspirantYou are spot on saying it almost works.
I did a hard reset. ORBI63 and its password are the default ones as shown at the bottom of the device.
