Kaiviti's avatar
Kaiviti
RBS350 — Orbi AX1800 WiFi 6 Dual-band Mesh Add-on Satellite
I've connected the Orbi AX1800 (RBS350) add on satellite with a ethernet cable to the Orbi AX1800 (RBR350) router to create a backhaul connection which works on a single SSID, but its showing up on ...
  • FURRYe38's avatar
    Yes. Bring the RBS to same room or near the RBR and wirelessly sync the RBS using the sync buttons in back or the RBRs web page/Add Satellite wizard. Once fully wireless synced, ethernet connect it to make sure it connectes wired to the RBR. Both wireless and ethernet should show GOOD status and wireless should show 5Ghz for the connection and Wired for the ethernet connection.
